The filter works as expected until I click apply, then the spatial disappears from the map. The attribute table correctly reflects the filter. Possibly only date filters.
Hi @TL2,This is likely the same issue that is reported here: Re: Filter using "in the last" date no longer work... - Esri Community.
Please let us know if the behavior you are seeing is different.Thank you!
Katie
Maybe related to this bug? See this post:
https://community.esri.com/t5/arcgis-online-questions/filter-using-quot-in-the-last-quot-date-no-longer/m-p/1687013#M67970
This went out last night and the issue should be resolved now. Let me know if you see an issue. thanks!
We are hoping have this issue patched tonight.
I am having this problem currently but am not filtering dates. I am filtering a string of numbers (UserID) and it has disappeared and does not come back up. Unable to filter anything on my layer, even hosted layers that I previously filtered are no longer there. It is just blank
If you can share the map/layer I can take a look.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
