I’m unsure of the correct approach, so please advise.
(It is understood that I will likely have to make table changes in Pro to make this work (so that is a given.))
Here is the situation:
We have a main form that holds the point feature and questions (It will be used in the field). The inspector goes to a seed seller, gathers information and photos then returns to the office and uses the form with 4 tables to complete his inspection by filling out:
Fill out Part 1 and Part 2 – for Farm or Non-Farm Seed.
Fill out Part 1 and Part 3: for AG & Grass Seed.
Fill out Part 1 and Part 4: for Vegetable seed.
When the inspector gets back to the office the point feature will be opened to view the field inspection data and then go to fill out the relevant parts (ie. Pt 1 & Pt 2, etc. depending on the type/use of seed).
Is this feasible: Have a radio button in Part 1 where if the group Farm or Non-Farm Seed is clicked the inspector will see only Part 1 and Part 2 or if Veg Seed is clicked the inspector sees only Part 1 and 4 or Part 1 and 3 only for Ag & Grass Seed.
[I’ve tried doing calculations, relelvant expressions, and body::esri:visible to hide/show tables but w/o success. however I welcome any suggestions as I am still in the early stages of learning ].
P.S. The form with four tables are related to the main table pt feature and will, when published, be used in Experience Builder (used in the office) to do what has been described above (fill out Part 1 and Pt 2, etc.).
Thanks for your patience and help.
