I use photogrammetry to make a 3D of my drone shots. When importing the 3D Object Multipatch layer in ArcGIS Pro, the feature appears to be floating above the terrain or not properly aligned with the ground surface. I already adjusted the Elevation Settings in the Layer Properties to "On the ground" and corrected its Spatial Reference, unfortunately the feature displayed is not in a correct elevation.
