This is my code., wherein i want attributes of a layer to pop up on click..<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1" /> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Navigation toolbar</title> <style type="text/css"> @import "http://serverapi.arcgisonline.com/jsapi/arcgis/2.8/js/dojo/dijit/themes/claro/claro.css"; .zoominIcon { background-image:url(images/nav_zoomin.png); width:16px; height:16px; } .zoomoutIcon { background-image:url(images/nav_zoomout.png); width:16px; height:16px; } .zoomfullextIcon { background-image:url(images/nav_fullextent.png); width:16px; height:16px; } .zoomprevIcon { background-image:url(images/nav_previous.png); width:16px; height:16px; } .zoomnextIcon { background-image:url(images/nav_next.png); width:16px; height:16px; } .panIcon { background-image:url(images/nav_pan.png); width:16px; height:16px; } .deactivateIcon { background-image:url(images/nav_decline.png); width:16px; height:16px; } .style2 { font-size:xyz-large; position:relative; } </style> <script type="text/javascript"> dojoConfig = { parseOnLoad: true }</script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.8"></script> <script type="text/javascript"> dojo.require("esri.map"); dojo.require("esri.toolbars.navigation"); dojo.require("dijit.form.Button"); dojo.require("dijit.Toolbar"); dojo.require("esri.dijit.Popup"); dojo.require("dijit.layout.ContentPane"); var map, navToolbar; var resizeTimer; var identifyTask, identifyParams; function init() { esri.config.defaults.map.sliderLabel = null; var startExtent = new esri.geometry.Extent({ "xmin": -10858450, "ymin": 3300000, "xmax": -10858500, "ymax": 3365000, "spatialReference": { "wkid": 102100} }); map = new esri.Map("map", { infoWindow: popup, extent: startExtent }); //setup the popup window var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25])) }, dojo.create("div")); dojo.connect(map, "onLoad", mapReady); map.addLayer(new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer")); // var mymxdURL = "http://xxxxx258069d:x399/arcgis/rest/services/txx34/MapServer"; var mymxdURL= "http://xxxxx258069d:x399/arcgis/rest/services/txx34/MapServer" var mymxd = new esri.layers.ArcGISDynamicMapServiceLayer(mymxdURL); map.addLayer(mymxd); navToolbar = new esri.toolbars.Navigation(map); dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler); } function mapReady(map) { dojo.connect(map, "onClick", executeIdentifyTask); //create identify tasks and setup parameters identifyTask = new esri.tasks.IdentifyTask("http://xxxxx258069d:x399/arcgis/rest/services/txx34/MapServer"); identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 3; identifyParams.returnGeometry = true; identifyParams.layerIds = [0, 1]; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; identifyParams.width = map.width; identifyParams.height = map.height; //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map, map.resize); } function executeIdentifyTask(evt) { identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; var deferred = identifyTask.execute(identifyParams); deferred.addCallback(function (response) { // response is an array of identify result objects // Let's return an array of features. return dojo.map(response, function (result) { var feature = result.feature; feature.attributes.layerName = result.layerName; if (result.layerName === 'TX__GOLIAD__PIPELINES') { //console.log(feature.attributes.OBJECTID); var template = new esri.InfoTemplate("", "${STATE} <br/> Risk Score: ${Risk_Score}"); feature.setInfoTemplate(template); } else { var template = new esri.InfoTemplate("","No element found"); feature.setInfoTemplate(template); } // else if (result.layerName === 'Building Footprints') { // var template = new esri.InfoTemplate("", "Parcel ID: ${PARCELID}"); // feature.setInfoTemplate(template); // } return feature; }); }); // InfoWindow expects an array of features from each deferred // object that you pass. If the response from the task execution // above is not an array of features, then you need to add a callback // like the one above to post-process the response and return an // array of features. map.infoWindow.setFeatures([deferred]); {Exception: Object doesn't support this property or method} map.infoWindow.show(evt.mapPoint); } function extentHistoryChangeHandler() { dijit.byId("zoomprev").disabled = navToolbar.isFirstExtent(); dijit.byId("zoomnext").disabled = navToolbar.isLastExtent(); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <table> <tr><td class="style2" align="center" bgcolor="#8080FF" valign="baseline" colspan="2">xyz GIS Dashboard<hr /> </td></tr> <tr> <td class="style2"> </td> <td> <div id="navToolbar" data-dojo-type="dijit.Toolbar"> <div data-dojo-type="dijit.form.Button" id="zoomin" data-dojo-props="iconClass:'zoominIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);}">Zoom In</div> <div data-dojo-type="dijit.form.Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);}">Zoom Out</div> <div data-dojo-type="dijit.form.Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon', onClick:function(){navToolbar.zoomToFullExtent();}">Full Extent</div> <div data-dojo-type="dijit.form.Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon', onClick:function(){navToolbar.zoomToPrevExtent();}">Prev Extent</div> <div data-dojo-type="dijit.form.Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon', onClick:function(){navToolbar.zoomToNextExtent();}">Next Extent</div> <div data-dojo-type="dijit.form.Button" id="pan" data-dojo-props="iconClass:'panIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.PAN);}">Pan</div> <div data-dojo-type="dijit.form.Button" id="deactivate" data-dojo-props="iconClass:'deactivateIcon' ,onClick:function(){navToolbar.deactivate();}">Deactivate</div> </div> <div id="map" style="width:1024px; height:512px; border:1px solid #000;"></div> </td> </tr> </table> </body> </html>None of the attributes are shown in the pop up..What am i missing here.Any help will be appreciated.
