Hi There,
I am trying to auto-populate addresses for the points collect in Quickcapture. To do this I created a dynamic list for a project user input button that queries the address feature class. I have ~1,500 records. I started running into an issue where the address I was looking for was not showing up as an option. In Quickcapture, it looks like the max count is only 1,000 records... Has anyone else experienced this or know of a way to work around it? Thank you!
Hi Annie,
I found this blog post a while back and it worked! https://gis.stackexchange.com/questions/179017/how-to-increase-the-number-of-features-returned-by-an-arcgis-online-feature-serv
Wonderful! Thanks for sharing the blog post so others can reference it when needed.
Hi zjaffe_MapIT,
You might try increasing the maxRecordCountFactor setting for the feature layer to workaround the currently default limit of 1,000.
Update the maxRecordCountFactor property from "1" to "2" via the hosted feature layer’s REST endpoint using the Update Definition tool. This change should allow all features to be queried and displayed as expected across apps.
If for some reason that doesn't fix the issue for QuickCapture, I would recommend setting up a new case with Esri Tech Support for the purposes of suggesting it be added as an enhancement to a future build.
Documentation:FAQ: What are the limits of the maxRecordCount and maxRecordCountFactor properties at REST?https://support.esri.com/en-us/knowledge-base/faq-what-are-the-limits-of-the-maxrecordcount-and-maxre-000030432Update Definition (Feature Layer)https://developers.arcgis.com/rest/services-reference/online/update-definition-feature-layer/
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
