I have an ArcGIS Pro project which encountered an error when I was trying to create a feature class.
There is one geodatabase associated with this project. In the Catalog Pane, when I right-click the name of the geodatabase in order to create the feature class, I immediately get an error message that says 'Unspecified error' and this then puts a red exclamation mark beside the name of the project geodatabase (screenshots attached). If I click on the exclamation mark I am able to repair the geodatabase. Doing this removes the exclamation mark and it looks as if everything is okay.
I am then able to right-click the geodatabase and the 'Create Feature Class' window opens as normal. I enter the name of the feature class and all other details, click 'Finish', but then the name of the feature class goes red and will not create it (screenshot attached). Cancelling this and going back to the Catalog Pane shows the red exclamation mark beside the name of the geodatabase again.
I can go through this process over and over, repairing the geodatabase, trying to create the feature class, the process failing, but it just keeps going in an endless cycle.
Does anyone know why this is happening or how I might fix it? The geodatabase is saved to my C:Drive and is not shared with anyone. I also have a number of other ArcGIS Pro projects, but this issue is not happening to them, only to this one specific project. Any help is appreciated.
