Help! I seem to have forgotten how to project imagery to its correct location on a map. I have a .jpg image of Mountain Pass, CA (see attached) but when I try to add it to a map, it either shows up in Kansas on somewhere in the middle of the Pacific Ocean. I've tried defining the base map projection as well as defining the projection of the image (CA State Plane Zone V) but no luck. Any help would be greatly appreciated. Thanks.
Jim
These two tutorials may also be helpful for you:
https://learn.arcgis.com/en/projects/fix-data-when-it-appears-in-the-wrong-place/
https://learn.arcgis.com/en/projects/georeference-imagery-in-arcgis-pro/
Define Projection (Data Management)—ArcGIS Pro | Documentation
Note from the above
Overwrites the coordinate system information (map projection and datum) stored with a dataset. This tool is intended for datasets that have an unknown or incorrect coordinate system defined.
So it must be defined correctly as to what it is... not what you want it to be.
Once you have defined it correctly then you can project it to a different coordinate system.
Project Raster (Data Management)—ArcGIS Pro | Documentation
So your problem is to figure out what it is first by adding it to an empty map... no basemap, nothing. Then examine the extents of the layer to determine whether it has a coordinate system or is just an image which needs to be georeferenced to provide real world coordinates.
Georeference a raster to a referenced layer—ArcGIS Pro | Documentation
Thanks, Bob. I knew there had to be a tutorial or two that could help.
Thanks, Dan. Between your solutions and Bob's, this should solve my problem.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
