I have clients with there own local kml files.
And I wanted to create small web app that they will be able to load or drag\drop KML file into the page and then renderer it into KMLLayer (totally failed... ) any idea?...
then i was trying to use the sample of loading shape file
Add shapefile | ArcGIS API for JavaScript 3.17
It use Generate option of the portal but kml is working in different way
You need to Add item to the portal and its not generate something on memory like CSV\Shape file.
Beside adding item into the portal with some kind of authentication with proxy
Do you have any idea how can i implement it?...
Shahar.
