Hi all,
I have a group of layers in AGOL that I have published from ArcGIS Pro, where I have also defined style and symbology.
In my web map I have changed the symbology of one of the layers, but when I use the EDIT widget (in Experience Builder) acting on this layer it always refers to the symbology of the original map.
I discovered that it is connected with the symbology of the source layer I shared from ArcGIS Pro.
In the information pop up (see attached figure) I cannot disconnect the symbology of the source layer: "Proprieties cannot be reset because they are already referenced from the source layer"
Moreover, if the disconnection had worked, I also wonder whether I would have lost all the relationship of the source layer or not.
The only solution is to start from beginning my already advanced project!!!!
Thansk for any help!
