Is ArcGIS Monitor 2024.1 compatible with Windows Server 2025?
Hey @MariuszZ
I've had no issue using Monitor on 2025 as of yet, if you'd like to check to see the compatibility standpoint, it may be worthwhile to spin up a virtual machine with 2025 on it, and deploy monitor for a test. The only real issue I'm having is that the CPU will stop recording for a time until I stop and start the agent process.
Cody
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
