From everything I've found here and elsewhere, it seems that in ArcGIS Pro, you can set default color models and profiles at the application level, and you can set them for individual project items, but you can't change the default at the project level. Is that correct, or am I missing something?
I also see that in editable styles, one of the options is to change the default color model for new items. However, if you add a style to a project, that doesn't seem to override the default--i.e., if your application default is RGB, but the style default is CMYK, new items are still created in RGB. That makes sense, since there are multiple styles available in any project, so ArcGIS wouldn't automatically know which style's default model to use. So, is there a way to specify for a project that you want to use the default color model from a particular style? And if not, then what is the purpose of being able to change the default model within a style?
