HI,
Configured a Instant App in ArcOnline, but when I open it either in contents or under My Apps in Instant App , it is the template, not my map. The map has the correct name I gave it, but none of the content I configured, only the temple shows.
I went through the steps Esri Tech support has posted at https://support.esri.com/en-us/knowledge-base/arcgis-instant-apps-display-their-template-when-launche-000031161#:~:text=The%20cause%20of%20this%20issue,with%20your%20app's%20item%20ID.
but it does not work. I copied the URL and it was the same. In the tech support, the workaround is to copy the URL from the app configuration page and past it in the details page under settings. However, they are both the same URL.
