What is the Max Token Expiration Minutes that can be set in in Portal 10.6.1 or Portal 11.3?
The default is 2 weeks. Is there a way to extend the token expiration to 1 year or more?
Thanks.
It depends on what token you use, but below are the maximum token expiration minutes in Portal (even if you specify a value larger than the maximum, it won't honor it and will use the maximum supported value).
https://enterprise.arcgis.com/en/portal/11.3/administer/windows/specify-the-default-token-expiration-time.htm
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
