I made a full backup yesterday using webgisdr, and tonight I wanted to make an incremental backup, but when I tried to run webgisdr with a new properties file that had BACKUP_RESTORE_MODE = incremental, I got the following response:
Starting the WebGIS DR utility.
The point-in-time recovery is turned off in the Relational Data Store: https://my_domain:2443/arcgis
Use the changedbproperties tool within the tools folder of the ArcGIS Data Store installation directory to enable point-in-time recovery. Visit the ArcGIS Data Store help for more information.
Exiting the WebGIS DR utility.
I then attempted to enable pitr with:
./changedbproperties.sh --store relational --pitr enable
You are changing the following database properties:
...Point-In-Time Recovery: enable
WARNING: You are trying to turn on Point-In-Time Recovery. A backup will be created following the change, and that might take a while.
Changing database configurations could cause the database to restart. Please do not interrupt the process once it has started.
Do you want to continue (Yes or No)?
I responded with No. Does the response mean that just a data store backup will be performed? Do I need to delete my last full webgisdr backup and start over after changing the pitr setting? I checked all the online documentation and the community for more information, but couldn't find anything that gives me any confidence in how to proceed.
Any additional information is greatly appreciated.
