It would be helpful to have an option in the search widget to set a default layer to search from instead of defaulting to all layers. In most cases our users will just search an address but want the option to search for our organization specific layers, but because the default all layer search takes so long to go through they are required to uncheck all layers and select the geocoder every time they open the viewer. It would save some time and confusion to configure the widget to default to the layer (or layers) they typically use. eg:
This is the current behavior:
This is the desired behavior:
here's a quick mockup of adding it to layer source settings. may also be helpful to allow multiple default layers if people prefer a default set but still want additional layers as needed.
