The edit widget is down since the last update. Even if the widget is set correctly in the builder, the widget is saying "Add editabe layer" and then the widget become blank.
Anyone else have the problem ?
Thanks for your help !
Hi @Iv_Bso , the team has implemented a fix that may also have resolved this issue. Please could you let us know if you are still seeing the issue? Thank you!
Hi @AlixVezina, yes the bug is gone ! Thanks for your help !
Hi @Stephanie_F , so yeah the widget was configured and the app published long before the update. And the layers used are hosted feature layers (hosted in our portal).
So since the update it's impossible to use the widget even if I reconfigured the widget and republished the app.
Hi @Iv_Bso Do you have more details about this behavior?
Did you have the edit widget configured and saved in Experience Builder prior to the update last night and then re-opening you see "add editable layer" today?
If it was already configured, what type of layer were you using as the source and is it hosted in ArcGIS Online or elsewhere?
If possible, a Technical Support case would be ideal to look into this behavior more in-depth. https://support.esri.com/en-us/contact
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
