Attribute Assistant add-in in ArcMap used to have a "Validation Attribute Lookup" functionality were you could type in the first couple of characters and it would do a quick search against a table in the background and list a set of filtered choices top on a drop down to pick from. Something like an Autocomplete Dropdown control you would come across on the web.
I was not able to find an equivalent feature while setting up Attribute Rules in ArcGIS Pro. Is there something similar to the "Validation Attribute Lookup" available or did ESRI just take that feature away?
