I have a large map depicting the design of a river restoration project. I have a layout showing all the design elements along this 1 mile reach of stream. I'd like to break this down to detail different sheets comprised of smaller reaches of the full project extent. I've seen this displayed on CAD (probably) drawings from engineers. The main layout will show all the rectangular boxes (numbered design sheets) along the reach that depict the different detailed layouts. Then, each detailed layouts would show the map detailed to within each box.
I attached an example of what I've done - but it was super hard and tedious to put together.
The first layout shows the full project extent, divided up with rectangle polygons named SHEET 1, SHEET 2, etc. Then I tediously created different layouts that encompass the Sheet extents shown by the rectangular polygons.
To do this, I created polygons on the map, adjusted them to fit into my desired layout view (hard to do), then it was simply duplicating the layout and moving the map into place with the rectangle polygon as my guide.
There must be a better way??? (see attached pdf)
