Hi everyone, I have a feature class containing about 120 polygons. Many of these polygons are likely to change in the future, so I'm using ArcGIS Pro to edit them. However, I also need to share them in a web map and an Experience Builder app for the public to see how they are changing. Furthermore, for one thing that I need to do, it seems like the best option is to create individual shapefiles of each polygon in ArcGIS Pro, share them as web layers on AGOL, and then add them all to a group layer in my web map. My question is what is the most efficient way to manage all of these versions/platforms (or just tips for doing so)? When I edit the layer in ArcGIS Pro, I know I can overwrite the existing web layer, but that means it will also overwrite any custom popups, transparencies, etc., on the web layer? Is there a way to do this that doesn't also remove everything I've customized on the AGOL version? And then is there a way to somehow have the individual polygon shapefiles linked to the original layer so that changes I make in the original also appear in the individual shapefile? Please advise. File management is one of my weaknesses!
