We are upgrading SDE from 9.3.1 to 9.3.1(sp1). We downloaded the SDE complete suite but missing the PE.pdb in particular. We could find it in the previous version (e.g. pe-sdk-bin-9.3.1-b1632-windows.zip) for both x32 and x64 platforms. The pdb is important for our development.Thank you so much and we're looking for this file urgently.Eric
Eric,Will you contact me at mkennedy at esri dot com? The standard SDKs don't include the pdb (nor debug build) files. There were only two fixes for the projection engine for 9.3.1 SP1. One was for Java: if you tried to retrieve the horizion for several projections, it would crash. The other change was to improve performance when confirming whether two versions British National Grid are the same (we changed the scale factor in 9.2).Melita
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
