This is a fairly broad question, with multiple potential answers. I'm a bit unsure on how to best do what I want. I feel a bit silly for having to ask such a basic question 🙂
I have point features in a feature service with a radius attribute. I have polygon features in a different feature service. I would like popups for the points to list features from the other feature service which intersect within the points attributed radius. Ideally, I would be able to click each of the listed intersecting features and zoom to the polygon on the map.
I have succesfully written an attribute expression which lists the features as text, but all in the one attribute.
// Write a script to return a value to show in the pop-up.
// For example, get the average of 4 fields:
// Average($feature.SalesQ1, $feature.SalesQ2, $feature.SalesQ3, $feature.SalesQ4)
var portal = Portal('https://www.arcgis.com')
var fields = [
'name_trading',
'variety1',
var fs = FeatureSetByPortalItem(
portal,
'############################', // FeatureService ID that you want to grab fields from.
0, // Sublayer index, usually 0.
fields, // Array of fields to grab from the FeatureService.
False // Include geometry?
var featurelist = [];
var radius = $feature.service_area
var buffer = Buffer($feature, radius, 'kilometers')
var inter = Intersects(fs, buffer);
for (var f in inter) {
var name = f["name_trading"];
var var1 = f["variety1"];
Push(featurelist, name+" - "+var1);
return featurelist
I've previously written a different function using the following array structure, which I can't work out how to implement in this situation to make each listed feature it's own field. And even if I could, I don't think I can zoom to each feature via a click if I made this display as intended.
var newfields = [
{ alias: $feature.variety1 , value: $feature.var1_perc },
{ alias: $feature.variety2 , value: $feature.var2_perc },
{ alias: $feature.variety3 , value: $feature.var3_perc },
Alternative ideas that I can't quite get my head around implementing right now:
- Arcade element in the popup which displays some sort of list. I can <a href> from this, but I don't think I can zoom to features. So might not accomplish what I want still?
- Click within the point popup maybe, which opens a Near Me tool, inputs the attributed radius as a distance, and return the features within that radius. I just can't quite understand the workflow here.
Am I missing a more obvious idea? I would appreciate any ideas or directions anyone has to offer.
