I have around 3000 occurrences (Lat long) of an invasive species. I am interested in finding the land uses where this species is found. for that, I overlaid these occurrence data on landuse map (raster). I projected the species data shapefile to the same projection of the land use map. I want to find the land use where each occurrence is overlaid. So finally the attribute table of the species shapefile needs to have another column with the land use type where the record is found. Can somebody suggest the tool that I can use to join respective land use data to the species shapefile?
