I have a Single Page Application (SPA), which is accessible under
http://localhost:8080/
In addition I have a MapServer hosted on a local arcgis server instance with the following URL
http://localhost:6443/arcgis/rest/services/myservice/MapServer
Due to authentication in production, this MapServer must be proxied through my backend , which handles authentication against the ArcGIS server services. So the service is accessible through the following URL
http://localhost:8080/proxy/myservice
Now in that SPA, I create a MapImageLayer instance using the proxy URL:
import MapImageLayer from "@arcgis/core/layers/MapImageLayer.js";
const layer = new MapImageLayer({
url: 'http://localhost:8080/proxy/myservice'
await layer.load();
const sublayer = layer.sublayers.at(0);
await sublayer.load();
At first everything seems fine, because
assert(sublayer.loadStatus === 'loaded')
does not fail, but members like fields, renderer or labeling info are not populated properly.
So I took a look at my browsers network log, which logs a 404 request to
http://localhost:8080/layers?f=json
I assume that this request should fetch the Sublayer details, such as fields, renderer or labeling info. But instead of instantiating the request relative to the SPA's root, the Sublayer details should be fetched relative to the layer proxy URL:
http://localhost:8080/proxy/myservice/layers?f=json
Is this actually a bug in the SDK, or something I can fix on my side?
---------------------------------------------------------------- 2024-06-20 - Edit ----------------------------------------------------------------
Note: The proxy implementation is irrelevant here. The bug can be reproduced with any proxy.
