Hi Royce,This error occurs because the second machine that you're trying to join to your existing GIS site, can't access either the configuration store or the server directories (or both) of the existing GIS site.You need to ensure that both the configuration store and the server directories of the existing GIS site are located on shared network locations that can be accessed and have read/write permissions by the ArcGIS Server account on the second machine.Joining an existing site help topicExpanding from one GIS server to multiple GIS servers help topicHope this helps,
Ok, so I updated the existing server's "arcgissystem" folder to be in the shared space along with all the others and now the new ags install can "join site". I hope that was the right call.
If you are using a domain account double check you have "Domain\User". I just had "User". Might be worth an add to your troubleshooting list as it is a silly mistake and not directly mentioned anywhere on this feed. I have setup many ArcServers and every once in a while overlook the domain part. It then just creates a user per your instructions which naturally has no access to the folders.
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
