Hello!
I was wondering if there is a possibility to smooth the boundaries of buffers around points that in the end NO boundary of the buffer is visible. The transparency of the buffer should increase by moving away from the central point.
Here an example:
What I am searching for is making the boundary of the buffer (red) completely invisible, so the buffer is increasing in transparency. In the middle of the buffer (point) should be the lowest transparency and around the boundary the transparency should strongly increase.
I am not sure if this visualization is possible since a polygon is limited by a boundary.
If anyone has any answers I would greatly appreciate it! 🙂 Thanks in advance!
