Hello!
I'm having an issue where the font "Microsoft YaHei" (built-in font for ExB) changes to completely different fonts on Apple/Android devices. Is that font not supported on Apple or Android? Are there problems with my ExB settings?
If there's nothing I can do, is there a similar font alternative I should be using that works for all devices? I already have an imported font for the body text so I can't import another one (frustrating that you can only do one, but I don't need to get into that here).
Has anyone else seen this before? Thanks in advance for any help or tips!
I’m guessing you’re not going to like this answer, but Microsoft YaHei is NOT licensed for redistribution / commercial use. See https://learn.microsoft.com/en-us/typography/font-list/microsoft-yahei for details. Microsoft licensed it for use in Microsoft products. I can’t fathom why Esri has it as a choice in Experience Designer other than that because it is included with Office applications, it is on a lot of Windows computers. Despite having the latest version of Office 365 on my Mac, I do NOT have YaHei on my machine. So, even though it is a choice in Experience Design on my computer, choosing it just changes it to my default serif font.
If you look at the code of a published Experience Design page you will see that although the font tags call for Microsoft YaHei, there is no mention of YaHei in CSS tags (linking to webfonts / woff2 font files). This means that IF you have YaHei on whatever machine you are using to view the webpage, it will work. Otherwise it won’t (doesn’t matter if it’s iOS, macOS, Android, or even Windows).
I’ve seen a couple of instances of Beijing Founder Electronics Co. Ltd going after people who even put screenshots of Word documents on their company sites where YaHei was visible, so unless you want HaYei badly enough to license it for commercial use (seems to be about $10,000), I’d highly suggest using another simplified Chinese webfont. Personally I recommend Noto Sans simplified Chinese (Google fonts link)
You’ll need to create your own theme in Experience design, but this is how you add your own font: https://developers.arcgis.com/experience-builder/guide/theme-development/#use-custom-fonts
Good luck.
This is great info, I had no idea about those font restrictions! (Like you said, why is Esri including it as a built-in font...? It's frustrating to have a practically unusable font as an option in the first place.)
I appreciate the explanation and font recommendation. I'm very familiar with custom themes so I will definitely try it! Thanks!
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
