Server Version 10.6.1
Geoevent Server successfully federated with ArcGIS Portal in Same VLAN and no port restriction in network. All SSL certificates are network domain authenticated. and using https connection to communicate. Why Geoevent server is giving below error ?
Error MSG :
| Failed to create connection cxn-34200 com.rabbitmq.client.AuthenticationFailureException: ACCESS_REFUSED - Login was refused using authentication mechanism PLAIN. For details see the broker logfile. at com.rabbitmq.client.impl.AMQConnection.start(AMQConnection.java:351) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.rabbitmq.client.impl.recovery.RecoveryAwareAMQConnectionFactory.newConnection(RecoveryAwareAMQConnectionFactory.java:64) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.rabbitmq.client.impl.recovery.AutorecoveringConnection.init(AutorecoveringConnection.java:99) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:948) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:907) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.rabbitmq.client.ConnectionFactory.newConnection(ConnectionFactory.java:823) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:233) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.internal.ConnectionHandler$3.call(ConnectionHandler.java:227) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.internal.RetryableResource.callWithRetries(RetryableResource.java:50) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:227) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.internal.ConnectionHandler.createConnection(ConnectionHandler.java:115) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at net.jodah.lyra.Connections.create(Connections.java:68) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at com.esri.ges.messaging.jms.amqp.AmqpMessagingFactory$ConnectionEstablisher.run(AmqpMessagingFactory.java:1040) [55:com.esri.ges.framework.messaging.jms-messaging:10.6.1] at java.lang.Thread.run(Thread.java:748) [?:?] |
