The numViews property in the Sharing API returns the number of item views since item creation.
Example:
request: https://...../portal/sharing/rest/content/items/1e02627438d4450c9ba28cab07e620cb?f=pjson
response:
"numViews": 6
Is there a way to get the number of views for say the last 3 months?
Regards,
Marcel
No, numViews is not tied to any specific timeframe. This is a simple theory, but perhaps you could try some kind of script/attribute rule to copy numViews to a new field every day and add a date/time field.
I'm trying to find a way to do the same thing.
I'm using the notebook from here: https://www.esri.com/arcgis-blog/products/arcgis-online/administration/managing-arcgis-online-content-with-arcgis-dashboards-and-arcgis-notebooks/
I've also found this: https://support.esri.com/en-us/knowledge-base/how-to-identify-the-usage-of-items-in-arcgis-online-usi-000021762
I'm gonna try combine the two. I'm just hacking away though so would appreciate anyone's ideas.
I'm not sure if this will help you, but if you need to reset/baseline your views back to zero in order to implement some kind of temporal tracking aspect, I posted some steps of how to modify numViews via ArcGIS Portal's backend PostgresSQL database here - good luck!
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
