Hi all,
This request for the AGOL version of ExB is pretty basic, my apologies in advance if someone has posted a similar idea in the past. I have searched through and cannot find an ideas request that covers it though.
Workflow
When selecting an object in a map widget, in many cases I would subsequently like to deselect that object. By deselect I mean universally deselect, so all widget and framework actions/triggers would also be deselected.
Implementation
I would like there to be a tool which I can activate in the map widget via the config panel, appearing as a small button in the map widget which will serve this purpose and no other purpose.
How will this help?
Currently users are having to click 'outside' an object to deselect. When viewing polygon layers clicking outside to deselect is often not possible. As we will build more complex data-centric apps it becomes easier for non-technical app users to get confused. The addition of a universal deselect option will help to reduce that confusion.
Andrew
