I'm attempting to utilize an entry in a repeat loop. The entry is an alpha-numeric text that associates the name of the entry to a range of fields. A series of questions are nested in a repeat loop and utilizes several select_one's and select_multiple, all of these parameters should correspond to one single repeat entry.
I want to use this data and select the entry name as a reference for calling corresponding data, ideally in a drop box, like select_multiple.
In short: Assign a select_multiple with answers from a repeat loop in current survey.
Can anyone shed some light on how this can be accomplished?
