I believe you are referring to this http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Classifying_numerical_fields_for_graduated_symbology/00s50000001r000000/.Using Web API's you can use the same symbology defined in your service or you may overwrite with your own ClassBreaksRenderer as shown in two following examples: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#RenderersXAMLhttp://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerRenderingHere's more documentation about it: http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ClassBreaksRenderer.html
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
