I have built a Web Map Application to edit a permitting layer based on an ArcGIS solution. The feature layer is created by loading our data into the solution through ArcGIS Pro. If I open the Web Map, the editing attribute popup always comes up and I can edit the layer. However, when I open the Application that is created from this web map, sometimes I get the attribute editing popup and sometimes I can only get the identify popup. I have not figured out the rhyme or reason to this. Does anyone have any ideas as to why this happens? This really needs to have that editing popup every time. I don't know if this is just a bug because I am using a solution.
