Here's the problem. I designed the tkinter library add-ins as modules. then I gave the events for these add-ins. Then I put the modules in C:\Program Files (x86)\ArcGIS\Desktop10.8\arcpy and imported them.
from MaxAddressDataButton import MaxAddressData
After this import, I took the instance of the class below and called it, everything works fine until here.
The problem is when I press the button in arcmap environment, the window comes up and stops working. What could be the cause of this problem?
I can't do it in koda debug so I can't see it either.
