ArcGIS Dashboardでデータダウンロードを活用できることをご存知でしたか?この機能により、ダッシュボード内でのコラボレーションやデータ共有が簡単になります。短いビデオを見てその方法を学びましょう。このビデオは2022年12月にArcGIS Dashboardsを使用して録画されました。<\/P>
<\/P>
さらにArcGIS Dashboardsのトレーニングを受けたい方は、Esriの「Working with ArcGIS Dashboards」コースをご覧ください: <\/SPAN>https:\/\/go.esri.com\/working-with-arcgis-dashboards-course<\/A>. <\/SPAN><\/P>https:\/\/players.brightcove.net\/6161463677001\/default_default\/index.html?videoId=6318140304112
Michael,
Thanks for the video. I'm having an issue in a Table widget where the source data download generates an error, the summarized data downloads fine. Any ideas to a cause/fix?
Chris
Hey Chris!Here is an awesome Tech Article that outlines some of the causes of and solutions/workarounds for enabling data downloads in your ArcGIS Dashboard.Also, when data download is enabled, data can only be downloaded by users who are signed in to an ArcGIS Online account. For dashboards shared publicly that include elements with data download enabled, anonymous users do not see the Download data option on the element.
Let me know if this helps in the error that's generated for you!Cheers,Mike
Hi @MichaelVasaya , is there a reason why users must be member of the organisation to be able to download publicly shared data (with download enabled) from a publicly shared dashboard? Using experience builder, table content (and features) can be downloaded (as csv, json...) without login...
Thank you,
Annina
Hi, I am struggling to find resources on how to enable the "allow source data download" setting when using ArcGIS Server Manager instead of a hosted feature layer in AGOL. We are using an enterprise server. Do anyone know how I should proceed to enable this functionality?
First you must be running Enterprise 11.2 or greater. The setting is found on the General tab of each widget in the actual dashboard. This way you can configure your dashboard to allow downloads from specific widgets instead of them all.
@MichaelVasaya
How can i do the same image icon(GIF) or its a video..Could you please guide me as shown in the attached article video and snaphot attached here
サインインしたメンバーは投稿、更新のフォローなどができます。初めてですか?無料アカウントを登録してください。
