Hi.
The version of arcgis javascript I'm using now is 4.24.
I am currently implementing the highlight processing of the selected object on the layer using the tool of the Sketch Object, but if I select polygon, square, or circle, the geometry object is inquired and returned, but if you select the object on the layer using the point tool, the geometry object is not returned. I'll write my source, so if there's anything wrong, please correct it.
In the source below, if I select with point tool, I get zero in the red letter of the bold part.
Please, help me.
let allLayerUrl = 'https://services-ap1.arcgis.com/Hs0yGgyc5IFRgIXc/arcgis/rest/services/GEOIS/FeatureServer';
let boreholeLayerUrl = 'https://services-ap1.arcgis.com/Hs0yGgyc5IFRgIXc/arcgis/rest/services/GEOIS/FeatureServer/0';
let projectLayerUrl = 'https://services-ap1.arcgis.com/Hs0yGgyc5IFRgIXc/arcgis/rest/services/GEOIS/FeatureServer/1';
let projectPointLayerUrl= 'https://services-ap1.arcgis.com/Hs0yGgyc5IFRgIXc/arcgis/rest/services/GEOIS/FeatureServer/2';
const boreholeLayer = new FeatureLayer({
url: boreholeLayerUrl,
outFields: ["*"]
const projectLayer = new FeatureLayer({
url: projectLayerUrl,
outFields: ["*"]
const projectPointLayer = new FeatureLayer({
url: projectPointLayerUrl,
outFields: ["*"]
gisMap = new WebMap({
portalItem: {
layers:[projectPointLayer, projectLayer, boreholeLayer]
gisView = new MapView({
container: "viewDiv",
map: gisMap,
extent: {
xmin: 1.4143672753287151E7,
ymin: 4523114.166998532,
xmax: 1.4144828455598556E7,
ymax: 4523429.5509626325,
spatialReference: 102100
zoom: 17
graphicsLayerSketch = new GraphicsLayer();
gisMap.add(graphicsLayerSketch);
let removeLayerIds = ['WebTiled_5481', 'WebTiled_5071', 'WebTiled_7927', 'WebTiled_509'];
gisMap.loadAll().then(async () => {
$.each(removeLayerIds, function(i, v){
let removeLayer = gisMap.findLayerById(v);
gisMap.remove(removeLayer);
let dllLayer = gisMap.allLayers.find(function(layer){
return layer.title === "GEOIS - TB DLL LC";
let prjctLayer = gisMap.allLayers.find(function(layer){
return layer.title === "GEOIS - TB PRJCT LC";
let prjctPointLayer = gisMap.allLayers.find(function(layer){
return layer.title === "GEOIS - TB PRJCT LC POINT";
gisMap.reorder(dllLayer, 7);
gisMap.reorder(prjctLayer, 6);
gisMap.reorder(prjctPointLayer, 5);
if(isFindGis == 'Y'){
moveToSelectedArea();
.then(function() {
return gisMap.basemap.load();
.then(function() {
allLayers = gisMap.allLayers;
const promises = allLayers.map(function(layer) {
return layer.load();
setLayerVisible(true);
return Promise.all(promises.toArray());
.then(function(layers) {})
.catch(function(error) {});
const sketch = new Sketch({
layer: graphicsLayerSketch,
view: gisView,
creationMode: "update",
updateOnGraphicClick: true,
visibleElements: {
createTools: {
point: true,
polyline: false
selectionTools:{
"lasso-selection": false,
"rectangle-selection":false,
settingsMenu: false,
undoRedoMenu: true
gisView.ui.add(sketch, "top-right");
sketch.on("update", (event) => {
unitGraphic = event.graphics[0];
if (event.state === "start") {
queryFeaturelayer(unitGraphic.geometry);
if (event.state === "complete"){
graphicsLayerSketch.remove(unitGraphic);
if (event.toolEventInfo && (event.toolEventInfo.type === "scale-stop" || event.toolEventInfo.type === "reshape-stop" || event.toolEventInfo.type === "move-stop")) {
const parcelLayer = new FeatureLayer({
function queryFeaturelayer(geometry) {
let type = geometry.type;
const parcelQuery = {
spatialRelationship: "intersects",
geometry: geometry,
outFields: ['*'],
returnGeometry: true
parcelLayer.queryFeatures(parcelQuery).then((results) => {
console.log("Feature count: " + results.features.length)
displayResults(results);
}).catch((error) => {
console.log(error);
function displayResults(results) {
results.features.map((feature) => {
feature.symbol = highlightSymbol;
addedFeatureMap.set(parseInt(feature.attributes.DLL_SN), feature);
return feature;
gisView.graphics.addMany(results.features);
if(results.features.length > 0){
processSelectedArea(results.features);
