This is probably simple but for some reason I cannot return the field I want in a popup.
This is from a Survey123 feature layer with a repeat. Within it I have a field that creates a subject line that I want to use in my popup. Instead of returning the value it returns: object, FeatureSet
I've tried going through some of the Arcade solutions but when replacing with my data but then the popup returns blank.
var heading = '<h2>Event: '+$feature.Problem + ' | Location: '+ $feature.City + ', '+ $feature.State+'</h2>'
var geninfo = '<p><h3>' + $feature.Info + '</h3></p>'
var subject = FeatureSetByRelationshipName($feature, 'asset_capture',['SubjectLine'])
return {
type : 'text',
text : heading + geninfo + subject
