I have a several questions in regard to using the traverse tool to digitize an old parcel map. I would like an answer that is more in depth than, "See ESRI Traverse tutorial" since the page doesn't go over entering older parcel data like the one shown in the attached image.
1. How do I go about entering these angles more efficiently? Since no direction is given, I have been drawing right angle lines and using the deflection tool. This is really tedious since it requires me to convert from degrees, minutes and seconds to decimal degrees and subtract from 180 before finally entering the desired deflection angle. I am new to using the traverse tool and surely there is a better method for entering these lines.
2. How do I go about entering this curve with the given information? I'm unclear what the Δ=111°-05'-40" represents here. Is this a format for direction or is it just another way of writing the delta angle? Trial and error has not yielded any curves that even remotely resemble the attached parcel information.
I would really appreciate some help or direction toward useful resources.
Thanks in advance
