Hi - I recently have encountered a situation where I can no longer delete rows within the attribute table of a new layer I've created after doing a spatial join. I used to be able to select all rows that I wanted to remove through the Select by Attributes feature and then hit Delete, but now my delete button is grayed out. I feel like I may have inadvertently hit a button that has made these tables read-only when they're created, but can't figure out how to make it editable. Have been searching for a solution but have come up empty. I did recently upgrade to Pro v3.0.2, but not sure if it's that or if I changed a setting. Any help appreciated!
