Hello
I'm using the sketch editor to let the user draw and edit polygons on map
i want to let the user the option to move/rotate/resize etc
when i create polyline/polygone I can do it with no problem as I send the geometry to the sketch editor
but when i want to create a point, i cannot resize and rotate it, only move the point along the map
(because sometimes my point are represented with a symbol, for example, truck)
is such option even exist?
P.S
I know i can go directly to the geometry / SimpleMarkSymbol and change it properties, but that's not an optimal solution for me
