I cannot get my map to display in my Vue 2 web app. I've done my best to follow the typing guide for ES Modules as well as the set up for TypeScript. I've tried some suggestions others have done, and those don't work either. The app compiles and runs and shows no errors. But the map does not display at all.
Does anyone have any idea what I'm doing wrong?
//tsconfig.json
"compilerOptions": {
"strict": true,
"jsx": "preserve",
"importHelpers": true,
"moduleResolution": "node",
"skipLibCheck": true,
"esModuleInterop": true,
"allowSyntheticDefaultImports": true,
"sourceMap": true,
"module": "ES2020",
//"moduleResolution": "Node",
"resolveJsonModule": true,
"target": "ES2020",
"baseUrl": ".",
"types": [
"webpack-env"
"paths": {
"src/*"
"lib": [
"esnext",
"dom",
"dom.iterable",
"scripthost",
"ES2020",
"DOM"
"include": [
"./src",
"src/**/*.ts",
"src/**/*.tsx",
"src/**/*.vue",
"tests/**/*.ts",
"tests/**/*.tsx"
"exclude": [
"node_modules"
}//main.ts
import Vue from 'vue'
import App from './App.vue'
import router from './router'
import store from './store'
import vuetify from './plugins/vuetify'
import { ADLogin } from "@wwinc/NPM-VueADRedirect";
import { SecurityService } from './services/security-service';
import 'leaflet/dist/leaflet.css';
import { Icon } from 'leaflet';
import esriConfig from '@arcgis/core/config';
//esriConfig.assetsPath = 'https://js.arcgis.com/4.24/@arcgis/core/assets';
//esriConfig.assetsPath = './src/assets';
esriConfig.assetsPath = '../node_modules/@arcgis/core/assets';
esriConfig.apiKey = "APIKEY";
type D = Icon.Default & {
_getIconUrl?: string;
delete (Icon.Default.prototype as D)._getIconUrl;
Icon.Default.mergeOptions({
iconRetinaUrl: require('leaflet/dist/images/marker-icon-2x.png'),
iconUrl: require('leaflet/dist/images/marker-icon.png'),
Vue.config.productionTip = false
console.log(`
Environment Settings:
logonPageURL: ${process.env.VUE_APP_LOGINSITE_URL},
logonApiURL: ${process.env.VUE_APP_LOGONAPI_URL},
redirectURL: ${process.env.VUE_APP_LOGINREDIRECT_URI},
baseURL: ${process.env.VUE_APP_BASE_URL},
apiURL: ${process.env.VUE_APP_REP_API},
Vue.use(ADLogin, {
router,
logonPageURL: process.env.VUE_APP_LOGINSITE_URL,
logonApiURL: process.env.VUE_APP_LOGONAPI_URL,
redirectURL: process.env.VUE_APP_LOGINREDIRECT_URI,
store,
debug: false
new Vue({
router,
store,
vuetify,
render: h => h(App)
}).$mount('#app')
Vue.$security = new SecurityService();
Vue.prototype.$security = Vue.$security;//main.css
@import "https://js.arcgis.com/4.24/@arcgis/core/assets/esri/themes/light/main.css";html,
body,
#app {
font-family: Avenir, Helvetica, Arial, sans-serif;
-webkit-font-smoothing: antialiased;
-moz-osx-font-smoothing: grayscale;
text-align: center;
color: #2c3e50;
padding: 0;
margin: 0;
width: 100%;
height: 100%;
.mapdiv {
padding: 0;
margin: 0;
height: 80vh;
}//vue.config.js
let CopyPlugin;
CopyPlugin = require('copy-webpack-plugin');
module.exports = {
publicPath: '/RepWrangler/',
configureWebpack: {
plugins: [
new CopyPlugin([
{ from: 'web.config', to: './' },
devtool: 'source-map'
transpileDependencies: [
'vuetify', '@arcgis/core'
devServer: {
disableHostCheck: true
//App.vue
<template>
<v-app id="app">
<v-app-bar
app
color="primary"
absolute
<v-img
class="shrink ma-2"
contain
:src="require('../src/assets/cowboy.png')"
transition="scale-transition"
max-height="40"
max-width="40"
<v-toolbar-title>
Rep Wrangler
</v-toolbar-title>
<v-spacer></v-spacer>
<v-tooltip bottom>
<template v-slot:activator="{on}">
<v-btn icon v-on="on" @click="logout">
<v-icon>mdi-logout</v-icon>
</v-btn>
</template>
<span>Logout</span>
</v-tooltip>
<template v-slot:extension>
<v-tabs align-with-title>
<router-link
style="display: flex"
to="/">
<v-tab style="color: white">Home</v-tab>
</router-link>
<router-link
to="/map">
<v-tab style="color: white">Retailers</v-tab>
</router-link>
<router-link
to="/reptable">
<v-tab style="color: white">Reps</v-tab>
</router-link>
<router-link
to="/zipsearch">
<v-tab style="color: white">Zip Search</v-tab>
</router-link>
</v-tabs>
</template>
</v-app-bar>
<v-main>
<router-view/>
</v-main>
</v-app>
</template>
<script lang="ts">
import Vue from 'vue';
export default Vue.extend({
methods: {
logout() {
this.$logout();
async beforeMount() {
await this.$store.dispatch('JWT');
</script>
<style>
#app{
background-color: var(--v-background-base) !important;
</style>//MapComponent.vue
<template>
<div class="mapdiv"></div>
</template>
<script lang="ts">
import Map from '@arcgis/core/Map';
import MapView from '@arcgis/core/views/MapView';
import FeatureLayer from '@arcgis/core/layers/FeatureLayer';
import esriConfig from "@arcgis/core/config";
async mounted() {
const apiKey = "APIKEY";
const map = new Map({
basemap: "arcgis-streets" // Basemap layer service
const view = new MapView({
map: map,
center: [-92.0932, 38.232], // Longitude, latitude
zoom: 5, // Zoom level
container: 'mapdiv' // Div element
const zipLabelClass = {
labelExpressionInfo: {
expression: "$feature.ZIP_CODE"
labelPlacement: "above-center",
const featureLayer = new FeatureLayer({
apiKey: "APIKEY",
url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/USA_Boundaries_2021/FeatureServer/3",
opacity: 0.4,
featureLayer.labelingInfo = [ zipLabelClass ];
map.add(featureLayer);
</script>
<style scoped>
@import '../main.css';
</style>
