Hi all,
I have registered a folder in arcgis server and validated it was success. Then from the same folder i tried to publish an image service by creating mosaic dataset, it shows successfully published to the arcgis portal.
But when I open the same service in portal it shows the data cannot be added to web map. In the server manager it shows the service is not started but when click on start it shows the "process crashed find the error log in the server path".
If I share the same mosaic dataset as map service it is published successfully and even can be seen in the webmap and server manager. everything works fine with map service.
Can anyone give solution for this or any suggestion what might be the issue for not starting the service? @HyderabadESRIInida
