Hi everyone, I was wondering if anyone knew if it was possible to set up an indicator in an ArcGIS Operations Dashboard via an arcade expression that would show a counter of how many features encountered an update to a specific field? I'm basically looking to track when a water meter's ID has been changed in an attempt to crack down on certain attributes not being updated as a result of the meter ID change (when they do not fill out the existing meter replacement related table information in the field).
Ideally the indicator would only show alterations to the meter ID field and nothing else.
If this could be done with the list element as well in the dashboard, even better!
Thanks in advance.
