Hello
Does anyone know if it is possible to filter parent records in a map based on a filter widget set up on a related table?
For example, I have parent records which are associated with a spatial point. The parent record contains name and date. The related table contains qualifications associated with each name. Is it possible for a user to select qualifications using a filter widget and then the map to filters to show just those records? I am not having any luck so far, but seems like this should work.....
Thanks!
