I am trying to use arcpy in ArcGIS Pro to set properties on layers including the description and summary. I am using
the metadata object to do this. The properties get saved. However, they are not used as the layer has not been set to
have it own metadata. How do I do this in arcpy? The current code is similar to the following
layerMetadata = layer.metadata
layerMetadata.description = description
layerMetadata.summary = summary
# The following do not have an effect
# layer.metadata = layerMetadata
# layerMetadata.save()
# This saves the metadata. However the layer is not set to use it
aprx.save()
