Hello all!
I am working on an Experience Builder application that will allow the user to view 'Work Request' points on a map. There is a list that will allow the user to filter, sort, and select the points.
I would like to have the list also update when the map's extent is changed - but only if the user wants to filter spatially. When the user does not want to filter spatially, then I want the list to ignore the map's extent changes.
Is there a way to allow the user to enable/disable filtering the data by extent? If not, has anyone developed anything similar in Experience Builder DE (I am asking as this app will be built using DE, so I can add functionality if I need to).
Thanks so much!
Chris
