I am attempting to set up an Inspection Workflow which utilizes both Field Maps and Survey 123. The inspectors use Field Maps to navigate the feature data and the pop up has a button which leads to the Survey123 form. However I am having issues.
After I create the link in the pop up and select a feature to inspect in my Field Maps map, it takes me to Survey123 but says that there is an "Error Unpacking". Can't seem to figure out what the issue is.
Additionally, when I bypass Field Maps and use only Survey123 on its own to complete the form, it submits OK but none of the inspection records show up in my related table. Very frustrating!!!
Hoping someone might be able to shed a little light on why this is occurring. I have been following @EricWagner1 's workflow, located here (https://www.youtube.com/watch?v=zVdOG_caI4o&t=16s) with no luck so far.
Thank you Esri Community, you are my only hope!!!
