Hello All,
I am working in Survey123 and I need some help with an If/Then statement. I am getting the following error when trying to convert the XLSForm:
B”ODK Validate Errors:\n>>Something broke the parser. See above for a hint.\nError evaluating field ‘leftcbavgheightnum’: The problem was located in calculate expression for ${leftcbavgheightnum}\nXPath evaluation: cannot handle function ‘If’\nCaused by: org.javarosa.xpath.XPathUnhandledException: The problem was located in calculate expression for ${leftcbavgheightnum}\nXPath evaluation: cannot handle function ‘If’\n\t… 10 more\n\nResult: Invalid”
Here is the calculation (If/Then statement) I wrote:
If(selected(${leftcutbankheight},'0'),0,If(selected(${leftcutbankheight},'<5'),2.5,If(selected(${leftcutbankheight},'6-10'),8,If(selected(${leftcutbankheight},'11-25'),18,If(selected(${leftcutbankheight},'>25'),25,0)))))
{leftcutbankheight} is a select one/text field
The result of the If/Then statement is a numeric decimal field ({leftcbavgheightnum}).
I am pretty new at Survey123. Any help would be much appreciated!
Thanks!
Eileen
