I'm writing a notebook to export a hosted feature layer that I own as a File Geodatabase item into my content, using item.export . This would be used as a backup copy of my data, if needed. I then intend to schedule a task for the notebook to have it run on its own periodically -- and ideally would like it to overwrite the previously-created backup each time so that I don't have a bunch of items creating clutter and taking up storage space.
The item.export method has an argument for 'overwrite' to replace an existing item, which sounds like what I need, however I'm either misunderstanding it or it doesn't seem to be working correctly. When I set overwrite = true, it just creates a new item in my content with the same exact name.
dataitem = gis.content.get(#itemid)
backupname = f'{dataitem.title} Backup'
dataitem.export(backupname, 'File Geodatabase', parameters=None, wait=True, overwrite=True)
Any idea if this is a bug or intended behavior? Is there a better way to do this? I tried using a search to locate the previous backup so I could just delete it -- but even when feeding in the exact item name, it would occasionally pull up some other item in the org.
