I have a value that can be housed in 4 different columns. Not only that but the value is within a text string. Here is an example of the string -
1-12: ESCC02SPL01, 1-12
I am trying to write an evaluation or batch calculation that searches the 4 columns for the value (contains 'SPL') and and populates a new column with the middle string (in between spaces) as the return. Such that the example above would evaluate to
ESCC02SPL01
Another detail is that I need the first instance of when SPL is in the value. So if it is present in columns 3 & 4, I need to take the value that is in column 3.
So far I am trying to put the columns in a list and then use Find to iterate over the list. I am more of a Python person so I'm not exactly sure how to do this with Arcade. What I have so far is this
var row1 = $feature.f0;
var row2 = $feature.f0spare;
var row3 = $feature.dead
var row4 = $feature.f1
var rowlist = [row1, row2, row3, row4]
var splitter = Find('SPL', rowlist, 0)
if (splitter > 0) {
return splitter
};But this is returning incorrect values.
Any help or opinions on this is greatly appreciated. Thanks for reading.
