Hey everyone,
I would really like to use FieldMaps to capture the location of our pipes for district heating when they are put into the ground. The challenge here is that I not only need the vertices for the line of the pipes, but at the same time I need to capture the locations where the pipes are welded together. It looks something like the screenshot I attached.
With the GPS we use at the moment I can indicate what to mease at a give point, where I am standing through a number of drop down menues. So lets say I am standing at a point along the pipeline where two pipes are welded together. Here I would indicate that I am about to measue a point/vertex for the line (for the pipeline feature class) AND a point where the pipes are welded together (for the point welding spot feature class).
It looks like you can only capture one element at a time in Field Maps. But can I pause the collection of points for the line while capturing a point, where the pipes are welded together and then go back to capturing points for the pipeline I was registering?
Thanks for reading my post. Any suggestions would be greatly appreciated!
Best regards Mette
